i cant get brake cover back on!?!?! help
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
i just finished putting the back shoe pads on, or at least 1 side and i cant get the brake cover back on. i got the new pads in and all the springs after 2 hours, and now theres not enough room for the brake cover. i tried adjusting the activator wheel, its all the way turned in and theres still not enough room,. does any one have any ideas!! im going crazy
and this is for a
1989 camaro 305 tbi
and this is for a
1989 camaro 305 tbi
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Adjusting the self-adjusting mechanism should give you more then enough room to get the drum back on. Make sure its all together correctly.
Engine: V8 350 ci
well does any one know a better guide to putting them back together i have a haynes, and its not very good, hard to tell what parts are what. ill take a picture tomorrow and maybe can notice something i did wrong, thx guys
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
I did mine with a Haynes manual and it was fine. Try just taking it all off and putting it on again and make sure it looks like the other side. (You are doing them one side at a time, right?)
Engine: V8 350 ci
yes i only did the right side, i will give it another go tomorrow, wish me luck ill keep you posted
1992 Trans Am
May 10, 2023 07:19 PM
sailtexas186548
Jan 19, 2016 12:21 PM
