Does Dash need to be removed for box install
Old Mar 19, 2006 | 07:34 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
Does the Dashboard need to be removed to remove the orininal AC/Heater box and Install a Non-AC Heater box? (I can't find the search function)
Old Mar 19, 2006 | 07:40 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
no. Just remove the old A/C one and bolt the non-A/C heater box in its place.
BTW, while the search is down, you can use Google to search TGO. Not as easy, but it works.
WTH? The new VBulletin now merges consecutive posts? Awww man, no more postwhoring!
Last edited by dimented24x7; Mar 19, 2006 at 07:44 PM. Reason: Automerged Doublepost
Old Mar 19, 2006 | 07:52 PM
Car: 1988 SC Camaro
Engine: 305 TBI
how to get it off
Ok. thanks..BTW, is there any "tricks" for getting the old box off?...I've removed several bolts, but its still on there pretty tight...are there bolts on the botom side that i need to get under the car to remove?
Old Mar 19, 2006 | 08:57 PM
Car: 88 Camaro SC
Engine: SFI'd 350
The lower bolts will have to be removed from inside the car. They are behind the carpet on the pass. side if I recall. The bolt/nut by the exhaust manifold will probably be the most difficult to remove.
Old Mar 20, 2006 | 11:50 AM
Car: 1988 SC Camaro
Engine: 305 TBI
I'm trying to install the Non-AC Airbox from "IROCDAVE". Has anyone had to modify the box or grind off the edges to get it to fit?...its fitting really tight at this point...any suggestions?
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
The_Phoenix
Feb 4, 2016 07:10 AM
3rdgenparts
Aug 8, 2015 07:09 PM
