View Poll Results: Which Option?
Keep L98, Heads, Cam, Intake in some form
100.00%
Cheap Crate, use existing TPI intake
0%
Rebuild LT1 with a Rod Knock, cam.
0%
Voters: 2. You may not vote on this poll
Decisions Decisions...
Old Mar 22, 2006 | 01:02 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Well guys, summer is coming up soon for me. I get out of college early May and start working, and plan on making 5000$ after taxes this summer. Half of that, I want to devote to my car which is an IROC 350 TPI, pretty much stock other than exhaust, and a shift kit which I will be installing this weekend hopefully.
Right now I have three options:
Option 1) Heads and Cam, port the hell out of the intake, and maybe pick up a set of SLP runners and siamese the hell out of those as well. Dutweiler Trick Flow heads, and a cam with close to .500 lift.
Option 2) Get a cheap crate motor with no intake, such as the one here http://goautocenter.com/320hp_alum__head.htm (also, scroll down, there is a 400hp engine for 2500$) and put my existing intake on it. I know that the HP numbers would be off thanks to the intake, but it would be relatively in the ballpark I think.
Option 3) (I just learned this today) Pick up an LT1 out of a 93 Trans Am and drop it into my IROC for next to nothing. The motor I can most likely get for less than 500$. The issue with this is that the motor has a rod knock, so I would end up rebuilding the entire bottom end, and doing piston rings while I was at it. That, I believe would wake the motor up a bit and have her running well. This idea is actually my favorite, since I will essentially be getting the motor and rebuilding it for under 1000$ (minus the can-o-worms fund).
Which option do you think will be the smartest out there to do? What kind of numbers can I expect from an LT1 (maybe get headwork done and a new cam =) ) after a rebuild? Any other opinions?
_Clark
Old Mar 22, 2006 | 01:32 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Is getting the trick flow heads, doing the LT1 intake conversion, and camming it with a custom PROM an option?
Old Mar 22, 2006 | 07:18 AM
I kind of wanted to stay away from the LT1 conversion just because it's a little out there, and I was thinkinging of going HSR instead, but the idea is open, yes
Old Mar 22, 2006 | 11:26 AM
Any other thoughts?
Old Mar 22, 2006 | 10:55 PM
up for the night
ZZ3Astro
Aug 13, 2019 12:57 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
3.8TransAM
Sep 3, 2015 06:38 PM
BlackTopKing
Aug 19, 2015 12:13 PM
