valve spring ID to valve guide OD clearance
Old Mar 22, 2006 | 04:42 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
I bought some new valve springs (comp cams #977) for my torker heads and they dont want to fit over the valve guide base without really pushing on them. What kind of clearance should I have here?
Old Mar 23, 2006 | 07:15 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
when you had your valve spring pockets cut to accept the 1.460 springs,(you did didn't you?) did you have your guide bosses machined for higher lift cams as well?
what kind of valve seals are you using?
something doesn't seem right,the 977 is a double spring with a damper and an i.d. of .700.that should be plenty of room to fit over the guide bosses,although they are a bit on the small side of the i.d range.
we are talking about the damper sprinh not fitting right?
i know they should not be forced on the boss,if it was me,i'd be calling comp and asking them what's up?
keep us posted!
Eric B
Old Mar 23, 2006 | 03:28 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
The pockets are were machined from the factory for 1.5 springs I believe. I havent mic'd the od on the guide but with a ruler it looks like almost a 3/4 inch. Havent put the seals on them yet but I have positive stop ones on the way. Its looking like I may have to get the heads machined down, which I doubt i'll be doing here in Germany. Really sucks.
Old Mar 23, 2006 | 05:22 PM
Shouldn't be a problem getting the machine work done. European motors have valve guides too.
Get the guides cut down to .530" OD (13.5 mm is plenty close enough) and use REAL valve guide seals such as Comp 503 or Crane 99820.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Amillionoh7
Sep 5, 2015 11:44 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
