I still got that sulfur smell...
Old Mar 23, 2006 | 06:53 PM
tigercyberslash's Avatar
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
i had a suffer smell do to a cogged cat, well i took cat off and replaced it with stright pipe to see if that was all the problem. well with the stright pipe im still getting that sulfur smell when i step on gas hard. Any idea where i can start to find what casueing the back pressure.
Old Mar 24, 2006 | 02:47 AM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
define sulfer, to some people its rotten eggs, to some its other things, i grew up near coal mines, i know sulfer smell.
If you think your exhaust is plugged up and you replaced the cat, well, what else could there be? Muffler? thats all there could be.
A burning sensation of the eyes with exhuast fumes is also said to be "sulfer" this is due to a rich condition, some times lean as well.
Old Mar 24, 2006 | 12:57 PM
Engine: V8 350 ci
yess the muffler is new....i think it may be runing rich or too lean...how do i fix this or find out is this is wrong. i was told that my car may be running to lean or rich before. The smell is like....gasy exhuast smoggy smell. doesnt do it when im driveing easy but when i try and take off fast , thats when it smells
Old Mar 24, 2006 | 01:49 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
i'm not getting the fact that it smells, exhaust shoudl never reak of sulfer, as i stated before its confused with other things but it is not sulfer.
if you can figure out what exactly it is, that would be helpful.
there are no coponents in our cars combined that would make enough sulfer through the exhaust for us to distiguish it outside in open air. Its nearly impossible. sure our cars in greta numbers make acid rain, but thats not just one car!
my guess is that your running lean, and in doing this your ending up burnign the exhaust components or the carbon buildup make a distiguished smell, but its not sulfer.
Try changing your fuel filter is this hasn't been done yet.
You could try by changing spark plugs an incomplete burn will cause rich conditions. They are $1.09/a piece for bosch super's at your local autozone.
Correcting a lean rich condition is difficult, if nothing has been done to the car as engine swap injector swap, maf and stuf the engine should basically have air/fuel down to a point. but it should never get far enough off to cause these conditons.
I still think its time for you to take a 2 hour long constant road trip, and breakin your muffler(if not already) and your "striaght pipe."
chazman
Aug 28, 2018 03:25 PM
chazman
Aug 22, 2015 02:01 PM
Darkshot
Jul 15, 2007 12:08 AM
ontogenesis
Jun 8, 2003 09:59 PM
MadZ28
Apr 21, 2003 07:54 AM
