serpentine set up help.
ok guys,im upgrading to a serpentine setup from an 88 up camaro.i have all the parts and have the 2 large aluminum pieces bolted on.my ?is does any have good pics of thier setup i can use .the only reason i ask is i was give the whole kit in pieces,and i have several braCKETS WHICH I CANT FIGURE OUT WHERE THEY BOLT UP TO.IM ASSUMING THEY GO BEYOND THE ALUMINUM AND OR ACCESORIES AND ATTACH SOMEWHERE TO THE BLOCK SO ID LIKE SOME PICS OR IF YOU KNOW WHERE THERE ARE SOME PICS POSTED
The only other pieces I can think of are 2 metal support bars that go from the brackets to appropriate studs on the exhaust manifolds. One on the passenger side from the side of the bracket where the A/C is to the 3rd exhaust bolt back and one from the side where the Alt. is to one of the exhaust bolts on the driver's side.
If you're using headers you'll have to fab up some spacers. If memory serves one was about 2" long, the other about 1-3/4" (don't quote me on that).
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
There's another metal bracket that runs from A/C compressor to top of intake manifold close to the water neck.
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
red90IROCls1
Aug 25, 2015 06:56 AM
mustangdmurder
Aug 21, 2015 07:17 PM
