anyone have a similar engine setup? vortec 355
Car: 1984 Z28
Transmission: TCI Streetfighter TH350
Axle/Gears: 4th gen 3.42
im just wondering if anyone has a similar engine to what ill be running
4 bolt 355 (350 bored .030") with a stock crank, eagle i-beam rods, forged pistons
vortec heads with a .467 lift cam.. 278* duration.. edelbrock intake and edelbrock 750 CFM carb
if so.. how do you like it? how much power are you making out of it? any track times?
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
ran 13.00 with a little smaller cam. But that cam is a good one. A good choice.
Should run easy 12's with slicks. Your heddman Y pipe leaves a bit to be desired. try the car uncapped (open exhaust) at the track to see the difference.
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
