serpentine heater hose ?,hurry
Old Mar 31, 2006 | 09:41 PM
anthony714's Avatar
ok guys ,help me out,upgrading to a serpentine setup,i have the new reverse water pump and an aftermarket radiator.my problem is i had an lg4 where the heater hose came out of the water pump.on my new reverse flow water pump theres no provisions for a hose.i looked at a factory sepr set up and the camaros with the serps ran the heater hose to the raditor .that would be fine if i had a radiator with a fitting on it.since my is a griffin it has nothing.has anyone(im sure they have)come across this dilema and anyone have a nice reliable fix.is it possible to jst tap into the intak efrom the front and the rear and make my heater hose circuit that way.im stuck here
Old Mar 31, 2006 | 10:31 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
If you get a new reverse rotation water pump from Advance Auto (ask for part number WP-715) you will get a pump that also has the provision for the heater hose fitting at the top of the pump...
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
