70's blocks
Old Mar 31, 2006 | 04:01 PM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
70's blocks
ok i have heard that engine blocks from the mid 70's had problems with the starter holes that were machined back to far. i think i have that problem cause i have a 75 block when i went to put the starter on it was to far away from the flexplate i could fit prolly 3 paper clips in between the flexplate and starter teeth. i was woundering would a mini starter work or would i have to get a special starter thanks.
Old Mar 31, 2006 | 04:25 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
i have a 72 block also.
are you trying to put an aftermarket starter on there, thats why its not working?
i havent had any trouble with mine, with an aftermarket starter.
Old Mar 31, 2006 | 04:27 PM
Car: 1987 iroc z
what flexplate do you have. i got a delco starter for a 74 vette and put on it. and was to far away.
Old Mar 31, 2006 | 05:17 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
shims?
Old Mar 31, 2006 | 05:38 PM
Brandons'86T/A's Avatar
Car: 86 t/a
Engine: 77 chevy 350
Transmission: stock
Axle/Gears: stock
i got a 77 chevy block in my trans, but its got lotsa room,
Old Mar 31, 2006 | 05:40 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
flexplate is from an 85 camaro
Old Mar 31, 2006 | 05:52 PM
Shims make it worse, when it's already too far away.
Old Mar 31, 2006 | 08:04 PM
Car: 1987 iroc z
ya its to far away without any shims
Old Mar 31, 2006 | 11:00 PM
ljnowell's Avatar
Are yousure you have the right starter/flexplate combo?
Old Mar 31, 2006 | 11:47 PM
Car: 1987 iroc z
ya its a 168 tooth flexplate and i got a starter from a 74 vette
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
