Need the name of a simple part
Old Apr 2, 2006 | 12:46 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Hey guys, when I was putting on my headers I broke what i think is a temp sensor. It screws into the block or head and is between cylinder 6 and 8 on the pass side of the enginea wire comes up and connects to it. When I took it out, lots of antifreeze came out. Do I have the right name for the part?
Old Apr 2, 2006 | 01:08 PM
Fan switch
Old Apr 2, 2006 | 01:31 PM
Engine: LB9, LB9
so pass side is fan switch and driver side is temp sensor?
by the way there is a screw in sensor futher down under this one so dont get it confused with that.
Last edited by 90CamaroTBI; Apr 2, 2006 at 01:32 PM. Reason: Automerged Doublepost
Old Apr 2, 2006 | 02:07 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Correct on the fan switch. I would get a lower temp one since you're replacing it anyway. There is a listing in the cooling section in a thread with part #'s, etc. Drivers side is the sending unit for the temp gauge.
LT1Formula
20
Nov 14, 2015 12:02 AM
nuggie
Aug 25, 2015 01:27 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
