Which belt to use with air pump delete
Old Apr 2, 2006 | 12:57 PM
TKO500's Avatar
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
I searched and found the belt to use when not using a air pump delete pulley is a 986K6.
However, for some reason I can not find anyone in my area that has this belt. My options are a 98" or a 99" long belt.
Will it matter which one I use? I have never run without the air pump before so I was not sure which is better. My thought is the tensioner will be able to compensate for either length so it wouldnt matter. Just wanted to get other opinions before I do it.
Old Apr 2, 2006 | 02:22 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
I am almost positive that I used the 98" belt on my smog delete setup. The belt number that is called for says its 96.8", but the part number they give gave me a 98" belt if memory serves me correctly. I think you should be ok...just make sure you get the 98" not anything longer.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
actionj
Carburetors
Aug 16, 2015 09:51 AM
mcquigg
Aug 13, 2015 02:26 PM
