ZZ4 cam lobe measurement.... help!
Old Apr 3, 2006 | 05:34 PM
shawntmartin's Avatar
Engine: ZZ4
Transmission: TH-350
Axle/Gears: 3:73
The widest part of my cam lobe (the fat part at the bottom where the valve is closed and the lifter is farthest down in the bore) measures 1 1/8th" (or 1.125") when I put calipers on it. Does anyone know what this measurement would be on a stock ZZ4 cam? This answer could save me hundreds of dollars...
Old Apr 3, 2006 | 09:38 PM
Mark 89Formula's Avatar
I measured from 1.170" to 1.210" across a number of lobes on a used ZZ3 cam. Has about 20K miles on it. That's more variation than I expected. All readings were larger than your measurement FWIW.
Old Apr 4, 2006 | 08:31 AM
Engine: ZZ4
Axle/Gears: 3:73
Well, 1.21 - 1.125 = .085 max difference. The lowest my lifter goes into the bore is still at the very top edge of the dogbone. So I would say that the lowest the lifter will go into the dogbone with the new cam is .085 from the top edge. The dogbone is .250 tall. 34% of .250 is .085....so the lifter will go down into the lifter about 1/3 of the height of the lifter....
So would you say I don't have to buy new lifters?
Old Apr 4, 2006 | 08:37 AM
Engine: ZZ4
Axle/Gears: 3:73
Sorry!! Let me rephrase that last part...
"so the lifter will go down into the dogbone about 1/3 of the height of the dogbone...."
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Magman
Sep 13, 2015 12:14 AM
Mr. Chevy
Sep 11, 2015 06:06 PM
