oops coolant in downtube
Old Apr 5, 2006 | 06:28 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
Okay so let me just start off with saying ive never pulled heads before, didnt realize there was coolant in the passage for the lower head bolts.
Headers were out and i unbolted the lower head bolt closest to the firewall, coolant comes pooouring out and into my downtube.
I just had a mandrel bent 3" system done, i would assume its all stainless. I have no real way of getting the coolant out of the pipe, should i be freaking out? if i do nothing itll stay in there for about 4 more weeks. Oh and the entire system is welded
Old Apr 10, 2006 | 01:00 AM
Vader's Avatar
It shouldn't be a problem. Expect a bit more steam and sweet aroma when you finally start the engine. It won't last very long unless more coolant is leaking in.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
