Voltmeter Showing No Charge
Old Apr 7, 2006 | 06:26 PM
89Z's Avatar
89Z
Car: '89 IROC Z
Engine: TPI 305
The needle on the stock voltmeter on the dash of my 89 Iroc Z (TPI 305 5 speed) indicates either just above, or in the red discharge zone when the engine is running. This has been happening intermittently for over a year. Recently, the needle is in the red zone just about all of the time. The alternator is new and the battery is definitely being charged because I can drive anywhere and the car always starts right up. Also, when the engine is not running, the voltage across the battery terminals is about 12.8V and when the engine is running the voltage is about 14.5V. Are the gages known to go bad on these cars? Is this likely a wiring issue? Has anyone else had this problem and if so what solved it?
Old Apr 7, 2006 | 07:43 PM
arnould78's Avatar
Car: 1991 Firebird
Engine: 305 TBI
Transmission: 5 Speed Manual
I would expect the gauge to be bad. I would check its wiring connections. If one of the connections is corroded bad or a wire is frayed, you will get a bad reading. You could probe around if the dash open with a voltmeter to test things.
Old Apr 10, 2006 | 02:46 PM
89Z's Avatar
89Z
Car: '89 IROC Z
Engine: TPI 305
Thanks for the help. I fixed it yesterday. The problem turned out to be a bad connection between the threaded post on the gage and the connection to the instrument panel.
Thanks again.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
3.8TransAM
Oct 1, 2015 07:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
RS Reaper
Sep 27, 2015 07:04 PM
