new engine startup
Old Apr 10, 2006 | 07:43 AM
adampousson's Avatar
Car: 91 firebird
Engine: 350 vortec heads
Transmission: t5
Axle/Gears: 3.08 open diff
new engine startup
i just started up my rebuilt motor for the first time.it misfires and flames shoot about 3 feet out of the headers.the guy thats helping me says the valves need to be adjusted they are way off.would that cause this or is this more of a timing problem?
Old Apr 10, 2006 | 10:31 AM
DLV555's Avatar
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
It's one of those. Either valve timing (or adjustment) or ignition timing.
Old Apr 10, 2006 | 10:57 AM
Car: 91 firebird
Transmission: t5
is it possible the carb is dumping way too much fuel causing the flames from header and misfire.pulled plug and it was pretty dark and still wet with gas 1 day after running
Old Apr 10, 2006 | 05:19 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Double check the firing order is correct,set the timing, then adj valves.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
