Computer Problem
Car: 1991 RS
Engine: 350 TBI
Computer Problem
I have a 1991 RS originally had a 305 TBI in it. I dropped a 350 TBI in it and having some problems that I cant figure out how to fix( Fan won't kick on w/o AC being on, Won't start when up to operating temp, slow throttle response) could any of that be due to the 305 computer in it. I went to the local automotive store and was told that the computer in my car is made only for a 305 and the 350 computer is different. Will that help with any of my problems?
Car: 89 camaro
Engine: 305 tbi
Transmission: 700 r-4
Did you change injectors and the knock sensor? Slow throttle might be caused by insufficient fuel. I am just thinking though. If you did do everything else then it is the computer. Just get a chip or prom made for you engine and it will run much better.
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Well if the computer still thinks its a 305 its trying to run thats definately a problem...
Either get a PROM for a 350 or better/easier just go to the JY and get the whole ECM.
