New Carb installed getting Code 45
Subscribe
Apr 10, 2006 | 11:59 AM
Hi everyone!
I did a search and couldn't find the answer, I don't know if this should be posted here or under carbs.
I installed a new Rochester quad carb, 02 sensor and EGR valve last weekend. She is running great and the RPM's are where they should be. The only problem is when I start her cold, she smokes gas, so it appears to be set to rich.
The car is now giving a code 45 (Oxygen sensor rich). So is the carb out of adjustment??? I have changed all the vacuum lines and sensors in the last 6 months. New cat convertor in January. She has 78,122 miles on her.
Thanks in Advance!!
Judi
Reply 0
Apr 10, 2006 | 12:52 PM
Is the choke opening up? It's electrically heated and won't open without beingg supplied 12V. There is a single wire connector popping out of the wiring harness that supplies voltage to the choke. Make sure it's hooked up and actually feeding it a full 12V while running.
Reply 0
Apr 10, 2006 | 01:23 PM
I'll check it tonight. Is there anything else I should look for?
Judi
Reply 0
Apr 18, 2006 | 02:07 PM
Problem solved!!
Hi all,
I just wanted to let you know, that it was the coolant sensor!!
She was reading -4 degrees, replaced the sensor and she is running great.
Judi
Reply 0
Apr 18, 2006 | 08:01 PM
Computer with a carb?? I thought the carb'd engines didnt have all that junk? No?
Reply 0
Apr 19, 2006 | 02:08 PM
Yes, the 1984 has a computer with a carb. Makes it hard to diagnose sometimes because the codes aren't always clear.
Judi
Reply 0
Subscribe
