HELP!!! Fuel System! Yikes!!!
Old Apr 10, 2006 | 03:48 PM
FBoDyV85's Avatar
Car: 89 IROCZ Camaro
Engine: 350 w/ Boltons
I have a new jasper reman that recently started making a noise. Sounds like a top end chatter type of noise. Kinda hard to explain. I brought it to a local shop thinking it was an engine valve problem of some sort. He had diagnosed the car with a faulty FPR. I then took the car home and bought a new Holley adjustable FPR 35-65lb. I installed it on the car and started it up. The same noise is there. I put a fuel pressure tester on it and the needle is jumping within 2lb's. With KOEO i can adjust it to 44 lbs without a problem. And the MAX pressure i can adjust to is 42-44lbs. I tried pulling injectors 1 by 1 to see if the noise goes away but it does not. The sound seems to be leaning on the driver side portion of the fuel system.
Does anyone have some suggestions on what to look at? Or little quick tests to rule some things out?
-Steve-
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Grant2k
Jul 10, 2018 04:01 PM
Fast355
Dec 2, 2016 06:33 PM
beachrodder
Aug 25, 2015 08:05 AM
