Starting problems
Old Apr 10, 2006 | 04:50 PM
lowgas&rubber's Avatar
Car: 97 b4c camaro
Engine: 350 lt1
Starting problems
This isnt regarding a third gen. but someone should be able to answer it. The car will start once in a while in park and other times will not even turn over or make a noise. When you stick it in neutral it will ALWAYS start. What could the problem be?
Old Apr 10, 2006 | 05:03 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Neutral safety switch out of adjustment???
snardos's Avatar
Car: 1992 camaro z28
Axle/Gears: 2.73:1
It is most likely the neutral safety switch, or could be in the shift linkage out of adjustment or something.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
