Dim Headlight Problem
Old Apr 11, 2006 | 03:08 PM
Beefy89's Avatar
The other night I noticed that my p/s headlight is dimmer than the d/s, so I replaced it but that wasn't the problem. When you hit the brights the p/s doesn't go bright, and I also noticed that the little blue light on the instrument panel is faintly lit when the brights are OFF.....Where should I start?
Thanks, Beefy
Old Apr 11, 2006 | 03:20 PM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
check all grounds....sounds you have a loose ground or a bad ground connection
Old Apr 11, 2006 | 03:22 PM
It's the ground on the pass side, if that's the side were the light goes out when you put it in Bright.
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
