No spark
Car: 1992 Z28
Engine: 5.7L 350 TPI
No spark
Car wouldnt start today so was checking and i wasnt getting a spark to the distributor so changed the coil and checked again still no spark, any ideas? the wire from coil to distributor is fine.
Car: '92 firebird
Engine: 305 HO
Transmission: 700R4 TCI performance
Axle/Gears: 10 bolt disc brake 3:42 slp auburn
Check to see if you are getting any power to the ignition module. If that isnt it i would check the crank position sensor which woult give your computer a signal to give it spark and fuel. Do you have an injector pulse width? check to make sure the check engine light is on with the key on engine off.
RedLeader289
05-28-2019 01:47 PM
HoosierinWA
10-07-2015 10:15 AM
