quick timing question
Old Apr 14, 2006 | 08:12 AM
berlincam86's Avatar
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
Is the tube on the timing tab 0 degrees and each notch in the tab 5 degrees or is it something differant? I can't see the tab to tell.
Old Apr 14, 2006 | 08:46 AM
The real deep notch is 0°; then each smaller notch is 4° from there.
Old Apr 14, 2006 | 08:49 AM
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
ok Thanks
Old Apr 15, 2006 | 07:39 PM
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
I see a wider notch next to the tube that's 0 degrees right?
Old Apr 16, 2006 | 12:29 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I'm getting a lot of mileage with this picture...Thank you montecarloss
Old Apr 16, 2006 | 10:15 AM
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
Oh yea that's perfect thank you!
Old Apr 22, 2006 | 06:55 AM
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
Ok another question, If I use my timing light while someone is cranking the engine over and I set the distributor to 0 degrees is this right? Or should i set it to like 5 degres before or something to get it started?
I've found out my carb is leaking that's why it won't start but I want to get the timing just right so I can be done with that or at least be close so when I fix the carb it will start right up.
Old May 1, 2006 | 08:29 PM
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
Ok I got it running the carb has been rebuilt and it fired right up.
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
