infl light?
Old Apr 14, 2006 | 08:30 PM
BowtieDriver2's Avatar
Car: '01 sonoma & '91 camaro
infl light?
I have a freind that has a 92 camaro 3.1 that will not start. the idiot lights come up but nothing else seems to work. he said the infl light stays lit. is this the airbag system? would this keep the car form starting?
the car will not try to turn over, fuel pump isn't priming, just the idiot lights. any ideas???
Old Apr 15, 2006 | 08:39 AM
Vader's Avatar
"INLF REST" is the warning lamp for the air bag. It should turn on when the ignition is turned on, then flash as the SIR system runs a diagnostic cycle, then turn off. It should have little to do with whether the engine starts. Since you have no fuel pump prime cycle, and no cranking, check the ignition switch and fusible links at/from the starter.
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
