can you tow a third gen?
Old Apr 17, 2006 | 09:50 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
I see the flames coming from a mile away.
I need to get my car to a shop thats a solid 45 minute drive on the highway. If i have to flatbed my car its going to cost a small fortune. Car is not running so i cant get it up on a tow dolly regardless.
The car is lowered idiot owners i think two guys before me cut the factory springs. The front gfx arent on the car though so that gives some extra clearance.
Theres no way i can get my car pulled by a normal tow truck is there?
Old Apr 17, 2006 | 10:43 AM
teapot3208's Avatar
Car: 1985 Camaro
Engine: 350 .030 over (355)
Transmission: 700-R4
no
Old Apr 17, 2006 | 10:45 AM
Beanx's Avatar
call robert wooley he will do it for free 812-466-5112
Old Apr 17, 2006 | 10:46 AM
oxiderush's Avatar
Car: 90 firebird
Engine: 350 5.7L
Transmission: Th-400 w/ Manual valve body
Axle/Gears: 4.10 Richmond gears
I doubt there would be any possable way, especially if it's lowered. I think you can get a u-haul trailer that gets all 4 off the ground. Maybe an option.
Old Apr 17, 2006 | 07:38 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Flatbed wreckers don't charge anymore around here than regular tow truck wreckers - it's the tow that costs, not the different types of trucks. Here, a 45 mile tow would be $90 if you know someone, $120 if you don't. It can be towed - if you can get under the front to lift it (which shouldn't be a problem with modern day tow trucks) - but you have to disconnect drive shaft from rear end and tie it up in the tunnel.
Old Apr 17, 2006 | 07:41 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Don't have to remove the driveshaft if they use good old fashioned dolly wheels.
Old Apr 18, 2006 | 04:39 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
Flat bed can do it for you. They have a bunch of differents ramps and planks. If you know someone with CAA, buy him a 24 and get her towed!
Toolsin
Feb 2, 2016 06:55 AM
my86bird
Oct 23, 2015 12:20 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
Ozz1967
Aug 16, 2015 10:23 PM
