Comp Cam Pro Mag rockers & centerbolt heads
Old Apr 17, 2006 | 09:26 PM
91RockS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI (L03)
Axle/Gears: 3.73 Truetrac posi
Can some confirm if Comp Cams Pro Magnum full roller rockers will work with centerbolt valve covers? I don't care if they're not self aligning, just want to confirm they don't require hacking up the valve covers baffles.
Old Apr 18, 2006 | 08:39 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
mine should work, got to turn the motor with them tight to make sure. stock valve covers wont for sure, you have to get a tall set to clear.
Old Apr 18, 2006 | 10:29 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
They work fine on aftermarket centerbolt covers. They also work with stock ones, but you have to remove the inside baffles and straighten a few of the gussets inside ( 5 minute job) Theres a post and link on here with pictures on how to do it.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
