Ignition Timing?
Old Apr 23, 2006 | 08:36 PM
Morit's Avatar
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
Ignition Timing?
How to bump up the ignition timing?
(probably a lame question but I dont know)
Old Apr 23, 2006 | 09:28 PM
cheese_kake's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Take the hold down clamp from the distributor, disconnect the EST wire. Then while the engine is running turn the distributor clockwise, get a timing light, and then if you can get a buddy to read the timing marks on the crank pulley. Then just adjust to your liking. Remember stock is usually a 6* BTDC so I would change it maybe 4* more.
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 18, 2015 02:28 PM
