rebuild or not rebuild
Old Apr 23, 2006 | 10:40 PM
blockbeeda's Avatar
Car: 1989 camaro
Engine: 350 chevy tbi
Transmission: 350 lock up shorttail
i have a strong 350 tbi recently put holly on top and now i have a tapping on right hand side of the motor when i accelerate idle,nothing.i use an stock electronic distributer wich i want to replace with a vaccum advance from a early model and scrap the electronic(can i do that)anyway i feel like its my camshaft thats about to give up on me but i still have the same power as i did before the tapping my timings all messed up and the tapping is scaring me should i break it down and rebuild or go with the cam lifters pushrod thing
Old Apr 23, 2006 | 10:46 PM
hotshotcamaro's Avatar
Car: 89 camaro RS
do you have a Carb on right now, non-computer controlled and still have a computer controlled distributor, if so you are prob. getting spark knock under accel, but i would think you would notice a lack of power on accel.
Old Apr 24, 2006 | 08:56 AM
blockbeeda's Avatar
Car: 1989 camaro
carb is electric choke holly and disrtibuter is electronic with the center wire going to the modual
Old Apr 25, 2006 | 10:26 PM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
If the timing's messed up, it's probably just be spark knock. When I started my most recent motor for the first time, I had all kinds of spark knock (bad timing mark on dampr) and it didn't effect power much at all. Try pulling some timing out of it. About 10* initial advance for a factory-like engine is all you really need.
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
3.8TransAM
Sep 27, 2015 08:37 PM
