Polishing Pistons Tops
Old Apr 24, 2006 | 08:17 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I will be ordering some forged pistons for my next build up. Just wondering if anyone has a good easy method to polish the piston tops?
Old Apr 25, 2006 | 09:51 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
one guy posted here a little while ago, chucked the pistons up in a mill, and used one of those abrasive nylon brushes and ran it over the piston top.
I just used a needle file to remove the sharp edges, then went over it all with 180grit sandpaper, then 400 grit. I could have used a felt bob in a dremel, with autosol polish too, but I didn't. A cross buff in a dremel/die grinder would probably work too. I have hyper pistons, which tend to have more shine due to the silicon I believe.
Old Apr 25, 2006 | 03:19 PM
Car: 1989 GTA
Engine: 369 TPI
Thanks for the reply. Going over the sharp edges is a good idea. I was already planning on the sandpaper route. That is what I will most likely end up doing.
Old Apr 25, 2006 | 04:01 PM
ede's Avatar
ede
bench grinder, buffing wheel, rouge (sic?) or emory compound
Old Apr 25, 2006 | 04:26 PM
Sonix's Avatar
Car: 1982 Trans-Am
sic? is that like "sp"?
damn, I wish I would have thought of that when I had mine out....
Street Lethal
Apr 30, 2019 12:14 PM
gixxer92
Sep 1, 2015 04:32 PM
kah992
Aug 19, 2015 02:55 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
