bent pushrod
Old Apr 25, 2006 | 09:11 PM
JFROG's Avatar
Car: 84 berlinetta
Transmission: auto
bent pushrod
would this have been causing the ticking noise? use stethoscope method with a wooden dowel. pinpointed to #4 cylinder. pulled the pushrod and it is bent, the rocker did have oil sitting on it and is not dry. re inserted and tried to spin push rod and felt like it was getting stuck at one spot in the hole. noticed shiny area where poss rubbing. try to attach pic. should i just replace them all while i have the cover off? what would cause to be bent?
Attached Thumbnails bent pushrod-july-4-05-xmas
Old Apr 25, 2006 | 09:15 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Is the engine completely stock?
Old Apr 25, 2006 | 09:30 PM
JFROG's Avatar
Car: 84 berlinetta
Transmission: auto
yes, as far as i know
Old Apr 25, 2006 | 09:33 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
I have always heard that if you replace one to replace every one of the pushrods.... it's not like they are expensive really
Old Apr 25, 2006 | 10:07 PM
JFROG's Avatar
Car: 84 berlinetta
Transmission: auto
i just hope that this is what was causing the tapping noise.
Old Apr 25, 2006 | 10:49 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Since everything is stock, you can rule out any valvetrain problems from mismatched parts. There is however a good chance you either have a collapsed lifter which could have allowed the pushrod to fall out or the cam lobe is worn out which shouldn't cause the pushrod to fall out. Is the rocker nut still on the stud roughly the same distance as all the other ones?
Factory pushrods are cheap as are new factory rockers and rocker nuts. Put a new pushrod in and replace the rocker/nut.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
slowsi
Oct 18, 2015 08:49 PM
Zell1luk
Sep 29, 2015 10:36 AM
mfp189
Sep 27, 2015 09:25 AM
