Shocking coil
Old Apr 26, 2006 | 07:23 AM
jstoll's Avatar
Car: 91 Formula
Shocking coil
I am getting a shock anytime I put my hand near the coil. I have enen put a new wire from coil to distributor. Is this a symptom of a bad coil. Also seems to cut out at about 4500.
Old Apr 26, 2006 | 09:44 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
sounds like it to me. prolly have part of the wiring of the coil shorting internally to the housing itself.
bad juju. replace
Old Apr 26, 2006 | 01:32 PM
Damon's Avatar
The insualtion on the coil itself has broken down or it's carbon-tracked, giving the high voltage side of the coil a path to the outside. If it can shock your hand it can easily zap straight to the metal "ring" around the coil and ground out as well.
Old Apr 26, 2006 | 10:48 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
You could have a bad wire or plug too with too much resistance. This will increase the voltage in the coil and make it possible to arc out at you.
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
