Help with vacuum line
Old Apr 26, 2006 | 11:12 PM
Mitre#136's Avatar
Car: 88 Pontiac Trans Am
Engine: 5.0L
Transmission: 4spd auto model unknown
Does anyone know where the little plastic line which starts off at what appears to be the smog pump is supposed to connect? Mine has just been hanging there since I bought the car. <?xml:namespace prefix = v ns = "urn:schemas-microsoft-com:vml" /><v:shape id=_x0000_i1025 style="WIDTH: 6in; HEIGHT: 324pt" type="#_x0000_t75"><v:imagedata o:title="vacuum help" src="file:///C:\DOCUME~1\HP_Owner\LOCALS~1\Temp\msohtml1\01\clip_image001.jpg"></v:imagedata></v:shape>
Old Apr 26, 2006 | 11:26 PM
z28camaroracer's Avatar
Car: 84 Z28, 89 RS, 98 SS
Engine: 350 .060 over, 350 .040 over, LS1
Transmission: TH350, TH700r4, T56
Axle/Gears: 4.11 spool, 3.73 open, 3.42 posi
If you are talking about the line that you have boxed in that line goes to the heater control valve.
Old Apr 26, 2006 | 11:35 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
mine melted on my header and my blend door has been open ever since
Old Apr 27, 2006 | 11:55 AM
Mitre#136's Avatar
Engine: 5.0L
Thanks for the help, that explains why i couldn't figure out why some of the lines from the smog pump were connected to the cooling system. Where does the hose from the heater control valve connect to?
gta892000
Aug 11, 2019 11:16 AM
camarohelp
Sep 12, 2015 05:45 PM
Doobie52
Sep 11, 2015 06:19 PM
IROCtometal
Sep 9, 2015 10:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
