moving the fuel regulator to the back?
Old Apr 27, 2006 | 12:39 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
I had a cracked fitting on my fuel lines and was spraying fuel everywhere on my way to the exhaust shop. I got it fixed, but need to redo my setup. I was thinking of moving the regulator to the back, and only running 1 line to the front to feed the carb. My question is, if I do that, will the added distance from the regulator to the carb cause a drop in psi? I'm assuming it wouldnt, but just want to be sure.
I'm running a 190lph electric pump that goes to my regulator that feeds my carb. I just want to mount the regulator in the back by the tank.
Old Apr 27, 2006 | 07:25 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There'll be a drop, but as long as you set it measuring the pressure at the carb it should be fine.
Old Apr 27, 2006 | 10:13 PM
Car: 88 Camaro
Engine: 310 LG4
that is what I planned to do, put my pressure gauge at the end of the hose that will go to the carb and make sure it gets what it needs. Thanks.
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
italiano67
Dec 11, 2016 09:21 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
