knock sensor??
Old Apr 28, 2006 | 07:21 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
knock sensor??
i was wondering if anyone knows this. does anyone know what sensor this could be...it is on the left side of the block,between the 5 and 7 plugs, i think it might be a knock sensor but i am not sure. right now it is just 2 end in each other, it slides in and out really easy. sorry i don't have any pics of it.but it is about 1-2 inches below the plugs.
Old Apr 28, 2006 | 08:16 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
if its in the head, its the thermostatic switch for the rad fan. The knock sensor is down near the starter, in the coolant drain hole in the block.
Old Apr 28, 2006 | 10:07 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If by 5 and 7 cylinders you really meant 6 and 8, then yes, it's the fan switch.
Old Apr 29, 2006 | 07:09 PM
no it is on the left side of the block when looking at it from the bumber. it is about an inch or two under the headers
Old Apr 29, 2006 | 07:13 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
down low in the block on pass side would be knock sensor
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
