Weird, very intermittent problem. Low idle, fans on...?
Old Apr 29, 2006 | 10:00 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
This usually happens to me every so often. And I can't figure it out. It never happens on a fresh start for the day, only if it's restarted. Anyway, you know how when you pull your codes, your fans automatically kick on no matter what?
Well I go out, fire her right up. Then I turn it off and restart it 5 minutes later. As soon as I restart it, I hear my fans come on, and the car is idling at 500 rpm and choppy (car was lucky to be at 120 degrees). No SES light or codes. Then I try to restart, and either it will idle again at 500, or start and stall. Then I let it sit 10-15 more minutes, and it fires perfect and idles at the 1000 cold, 750 warm in park.
I know for a fact the car is not throwing any codes, even when it was having its little misfit. This is about the third time it has happened to me in four years, so it's very intermittent.
But something is fishy, because everytime it does this, my fans or fan turns on, just like when your pulling codes, and my engine is not even close to hot or warm.
Old Apr 30, 2006 | 10:27 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Ut oh, I stumped the crowd.
Old Mar 18, 2011 | 06:14 AM
89shane350's Avatar
Car: 1989 Chevy Camaro IROC-Z
Transmission: 700R-4
Axle/Gears: Borg-Warner rear axle 2.77
Re: Weird, very intermittent problem. Low idle, fans on...?
update?
Old Mar 20, 2011 | 09:52 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
when you are pulling codes , i believe the only fan that comes on is your secondary fan on the passenger side. It is normal for the driver fan to come on after you shut the car off and just restart it though.
Old Mar 21, 2011 | 02:48 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Actually, the only fan controlled by the ECM is the primary fan. The secondary is controlled by the heavy duty fan switch or the AC fan press sw. You may have an intermittent problem in your ECM. Verify which fan is coming on. It may be an issue with your AC.
eightsixseven
Dec 16, 2024 01:50 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
CORV3TT3
Aug 23, 2015 11:26 AM
EFR2000
Aug 18, 2015 08:54 PM
perZ
Aug 15, 2015 01:17 PM
