aftermarket fuel filter??
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
what do you guys think about aftermarket fuel filters? i am in the middle of running new hardlines from the tank to the engine compartment, and figured the stock fuel filter should be replaced while i was at it.
i am looking at getting an aftermarket inline type - nothing special. i wanted to relocate it to the engine bay. i know this isnt rocket science, but anyone have any suggestions on what to use, as far as manufacturers, etc.? i know that the crap ones you see at autozone that are in their "performance" section probably won't cut it, so i thought i would ask.
by the way, the link below is kind of what i have in mind:
http://store.summitracing.com/partde...5&autoview=sku
thanks..
-brian
thanks..
-brian
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Those filters work great, I have one very similar. Mine is basically the same only russel brand. I chose russel because it already had the 8an male ends on it so I wouldn't have to buy more fittings for the ends of the filter. Only downside is they are expensive.
1992 Trans Am
May 10, 2023 07:19 PM
92camaroJoe
Aug 13, 2015 06:07 AM
