help me selecting fuel pump
Old May 1, 2006 | 02:48 PM
proxemics's Avatar
Car: 87 Z28
Engine: 383
Transmission: th350
Axle/Gears: ford 8.8
350ci with 445hp trick flow engine kit ,performer rpm intake,holey 750 carb and flat piston
I'll not drive the car for long distance
I need one good and fairly priced ,Electrical or mechanical
what fuel pump to get ? I want one with regulator
thank you
Old May 2, 2006 | 10:07 AM
proxemics's Avatar
Car: 87 Z28
Engine: 383
Transmission: th350
any one
Old May 2, 2006 | 10:10 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
you could use a holley red with a mallory 3 port regulator if you want.
or a mechanical one on the block, and stay simple and cheap. I think a higher end mechanical one on the block should feed that motor well. 110GP/hr should be enough eh guys?
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
