USE THIS CAM IN LT1 ??
Old May 2, 2006 | 04:00 PM
cheese_kake's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
When I was buying parts to build my TPI I bought a XE256 it has .449 / .456 int/exht. I just bought an LT1 motor and tranny the other day and Im putting it in soon. I was wondering if this cam is compatible, and if it is will it be worth it to use ?
Old May 2, 2006 | 04:33 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
That depends...
Comp makes it in 2 different versions, 1 for carb and one for EFI which has a wider LSA.
with tuning it shouldnt be too bad.
Wide LSA= EFI friendly
Old May 2, 2006 | 04:37 PM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Oh sorry I forgot , its got 112* LSA. Im just wondering if that would be better than the stock LT1 cam, or if it would even work ??
Old May 2, 2006 | 05:17 PM
Does it have the long dowel pin and the factory style roller apparatus on the front of it, to work in the LT1 block and hook up to the Optispark?
If not, it won't work.
Additionally, it's not a roller. It's a downgrade.
I'd recommend selling it, or trading it for something you can actually use.
Old May 2, 2006 | 06:03 PM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
No it is a roller cam, check it out at the comp site.
Old May 2, 2006 | 06:26 PM
You mean this flat tappet cam here, is a roller? This one, that's on p. 124 of Comp's catalog, with the other flat tappet XE cams? Hmmmm..... interesting.
XE256H
For LT1 cams, you want to be on this page here.
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
L0tuS
Sep 4, 2015 11:16 PM
Strick1
Sep 4, 2015 07:11 AM
