083 HEAD ASSEMBLY ?
Old May 3, 2006 | 07:25 AM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
083 HEAD ASSEMBLY ?
ok, ready to install springs on a set of cast iron 083 heads. got 2 more questions.
1. have obtained my installed spring height, but when i add proper shim they put the base of the spring above or right at the top of the spring seat. is this ok ? (shims .06 on intake & .12 on exhaust.)
2. is it normal that all the exhaust spring seats are cut .05 lower than the intake from the factory ? like they wanted different spring pressures on exhaust than intake ?
thanks, im trying to learn head building so all educated advise will be much appriciated.
mike
Old May 3, 2006 | 09:38 AM
1. I don't like that one bit. That could allow the spring to dance around on the head. Check the inner dia of the springs you're using; if they fit tight to the guide, within .030" or less, they'll probably be OK. If not, use some of these, such as part # 4695, and find the ones with the right ID and OD for the springs you're using. Another trick would be to use offset keepers, that REDUCE the installed height, instead of INCREASING it; such as Manley 13081.
2. The reason they're like that, is that the factory uses those stupid useless "rotators" on the exhaust valves. I & E use the same spring, but the exhaust has that big heavy extra thing on top of it, so they cut the pocket deeper.
Old May 3, 2006 | 10:02 AM
SPIKE's Avatar
Car: 86 CAMARO
thanks sofa, i thought it didnt look right. off to summit or jegs i go.
1992 Trans Am
May 10, 2023 07:19 PM
Chuck84TA
Jul 15, 2016 09:05 PM
C409
Sep 23, 2015 04:30 PM
gixxer92
Sep 1, 2015 04:32 PM
