bad fuel injector?
Old May 5, 2006 | 12:57 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
bad fuel injector?
i think i have a bad injector. how can i make sure of it? I know how to do the resistance test, ive swapped plugs with another injector. and this is the only cylinder (#3) where i can unplug it and feel no difference. i left it unplugged and rev'ed it and it sounded the same as always. have i done enough justifcation to say its bad? or is thier any more tests i can do? also. thesea re the ford svo's. can i purchase those seperately? i look at summit breifly but seems i can only get them in packs of 4.
Old May 6, 2006 | 12:09 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You could try pressurizing the line with your FP gauge hooked up.
Unplug that injector
Momentarily fire the injector from an external +12 and -ground source (wired from the battery will work) and see if the FP gauge drops pressure when you do so.
There are balance tester kits, run about 50 bucks or so, that does the same thing and are more accurate, but for just a quick test on one injector to see if it's clogged or working, you can do as I mentioned above.
Unsure about buying one or not.
sweet_87_iroc
Sep 25, 2015 10:01 PM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
