350 TPI w/ 4 speed ???
Old May 5, 2006 | 08:33 AM
cheese_kake's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
After I pulled out my 350 TPI for my LT1 swap, me and my buddy are deciding to put the leftover TPI in our 2.8 87 Camaro beater. I have all of the wiring, harness etc. The 87' has the 2.8v6 with a 4 speed standard. Will the TPI bolt up to this ? and if it does how long will the 4 speed last under the torque of the TPI ??
Old May 5, 2006 | 09:23 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
no. The v6 is a 60 degree motor and the v8 a 90 degree motor. The transmissions will not work.
Old May 6, 2006 | 01:29 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
you could use the trans that was mounted to that 350 TPI motor right? since you're using the new T56 that came with the LT1?
Old May 6, 2006 | 12:25 PM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Ya I guess were gonna do that, we wanted to use the 4 speed but since it wont bolt up right, were gonna use the 700r4.
Pac J
May 17, 2020 10:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Lmancha96
Sep 25, 2015 08:11 PM
89fast5oh
Sep 8, 2015 09:55 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
