brake help
Old May 6, 2006 | 10:28 AM
iroc_cragg's Avatar
brake help
1985 IROC
replacing the rear pads and rotors, and i cant get the the piston to sit back in the piston on the drivers side, I disconnected the ebrake and am using a c clamp but the piston wont go back in. any suggestions
posted on the brake board but noone helps over there
Old May 6, 2006 | 10:50 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The rear pistons don't press in, they screw in.
Old May 6, 2006 | 10:56 AM
iroc_cragg's Avatar
on 85 they screw in, how do u do that, in the manual it says they press in
Old May 6, 2006 | 11:36 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The manual says press in the front pistons. The rears have to be turned as they go in because of the threads on the parking brake mechanism. You can get a tool at the parts store to make it easier, or you can use waterpump pliers if you're extremely careful not to damage the piston face or the dust boot.
Old May 6, 2006 | 12:02 PM
iroc_cragg's Avatar
ok got the pistons in, went to mount everything back up and the aluminum brake line broke what can i do to fix this
Old May 6, 2006 | 11:26 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Probably have to replace the line.
Old May 7, 2006 | 01:05 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
the line from the center block to the sides is cheap ($5) and you can bend it by hand. I redid my hard lines due to corrosion.
BTW, what quadrant are you in? I've been seeing a lot of nice 3rd gens around now that the weather is nice, but few calgary members on TGO....
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
