Replacing the timing chain. Anything else I should get while I'm at it?
Old May 7, 2006 | 09:30 AM
joe350's Avatar
Car: 91 Z28
Engine: 350 TPI (L98)
If I'm gonna do all the work to replace the chain, I want to get other stuff out of the way as well. Sprockets, oil pan gasket, and water pump are pretty much a given. I'm planning on running kerosine or some other solvent through the engine before hand and then replacing the oil pump screen also. Anything else I should get while I'm at it? Is the oil pump worth replacing?
I don't think I'll be getting a new cam at this time due to the fact that I'm running the old stock heads with the old stock springs and I don't really have the time to be replacing them.
Also, roller cams rarely get worn correct? I ask because I'm replacing the chain due to a slightly rough idle and I want to be sure its not due to the cam but I would rather not have to remove the cam unless I need to.
Old May 7, 2006 | 11:04 AM
bretsk2500's Avatar
Car: 88 Chevy K2500
Engine: 350 TBI
Axle/Gears: 14b SF 3:73
also replace the woodruff keys in your crank. is your oil pressure ok? if it is you're just changing parts for the sake of parts, IMHO.
Old May 7, 2006 | 12:56 PM
joe350's Avatar
Car: 91 Z28
I will refer you to this post: https://www.thirdgen.org/forums/tech...ed-almost.html
Also, oil pressure drops significantly (as in down to 0) according to the gauge when the engine is warm and at idle. I attributed that to an old oil pressure sending unit, since it has been like this for over two months with no adverse affects (aka, blown engine).
Old May 7, 2006 | 06:12 PM
bretsk2500's Avatar
Car: 88 Chevy K2500
Engine: 350 TBI
your vacuum problem may be bad valve guides, given the exhaust smoke.
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
justin57
Aug 20, 2015 07:05 PM
MY87LT
Aug 17, 2015 08:43 AM
