is my cam gonna eat my lifters?
Old May 8, 2006 | 09:37 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
88 roller block with factory lifters... and an XE cam
233/239, .569/.577, 111
Old May 8, 2006 | 10:16 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
is it a roller cam? if not then possibly, also that is a HUGE cam for vortec heads, way too large of a choice. not to mention you're running too small a stall for it.
Old May 9, 2006 | 02:05 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
it won't eat the lifters.
but yea, maybe not the best cam choice for those heads, unless they've been really worked or something...
Old May 10, 2006 | 05:20 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I'll be mildly porting them, moreso the exhaust port. Gasket match and a polish, with a three-angle valve job as well.
But why is that not the best choice in cam for my heads?
And what would be a better stall speed?
Old May 10, 2006 | 05:59 PM
xpndbl3's Avatar
Car: 1984 Z28
well i'd look for a cam around a XE274 style. whether you get the 274 in solid lifter, solid roller, or roller, is all about the same lift. those heads flow worse at .550 lift than they do at .500 lift. Don't forget that the XE274 cam calls for 3000-3500 stall, you're choosing a larger cam so i'd say 4000+, which wouldn't be very streetable. i'm running a similar cam to the XE274 only a solid lifter custom grind and i'm running a stall right around 3600 behind this motor, with 4.10 gears and 28" slicks to be optimized. 850 DP and a super victor intake as well.
Old May 10, 2006 | 08:22 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I don't get why I need such a high stall... Is there zero low-end?
Jorlain
Oct 8, 2015 01:57 AM
Lanz06
Sep 14, 2015 07:16 PM
Stryker412
Sep 7, 2015 09:11 AM
dimented24x7
Sep 6, 2015 03:51 PM
z28guy134
Sep 1, 2015 11:50 PM
