400 sbc combo question????
Old May 9, 2006 | 07:27 AM
wheelstandin87's Avatar
Car: 87, 88 and 89 Iroc-Z
Engine: 305, and 350
Transmission: 700R, and T-5
Axle/Gears: 3:23 POSI
ive got a 400 sbc and i have world product torquer heads off of a 305 and i wanted to know if they would work good on the 400 i have????? thanks
Old May 9, 2006 | 08:25 AM
hot trans am's Avatar
Car: 1986 trans am
Engine: 406ci chevy small block
i do not know for sure if those heads will work but i think they will. if they do you must have the heads drilled for the steam hole. i had my eng. built and the shop that did the work told me that it is very importanty to have the holes drilled in the heads when using a 400 block. also i had one heck of a time getting my 400 to not overheat. i hope you do not have the same problems.
Old May 9, 2006 | 08:44 AM
Right, drill the steam holes. No big deal, just 6 holes per head. Use a 400 head gasket (7733PT2 or 1014) as a template, center-punch them, use a 3/16" drill bit. It's about a 10-minute job if you stop and knock back a cold one a couple of times. Less if you stay on task.
The heads will be "OK", but far from optimum.
If I was building a 400, I believe I'd look for something else. Sell those, and get something more appropriate. Look for heads with about 200cc intake ports.
You'll need to pay attention to what chamber size and what pistons you use, because you can end up with your compression all over the place. From 14:1 or more down to 7:1, if you choose wrong.
Power comes from flow. The more cubic inches you have, the more flow you need. Those heads are set up to deliver what a 305 requires. A 400 needs ALOT more.
It's not hard at all to keep a 400 from overheating. Don't hack your cooling system. The stock one is fine. Make sure it all works right, no leaks, correct thermostat, etc.; and make sure the motor has a REAL AGGRESSIVE timing curve. The timing too far retarded is the single biggest cause of overheating.
Old May 9, 2006 | 09:18 AM
thanks guys for all you help and comments much a preciative
Mickeyruder
Sep 2, 2015 02:45 PM
camaro71633
Sep 1, 2015 10:24 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
