Will 113 heads work?
Old May 10, 2006 | 08:34 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
on my TBI engine? I want to run some 113 heads on my car. They have the same sized combustion chamber as my 305 TBI (swirl port) heads, but I know aluminum can take higher compression than iron, but will this mess with the engines running?
Old May 10, 2006 | 11:05 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
i'm pretty sure they'll work well.
Old May 11, 2006 | 12:34 AM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
If the combustion chambers are the same size, then your overall compression ratio will be the same. It's not that the aluminum heads can take more compression per se, but they can take it without detonation. Plus they have better heat radiation characteristics and are lighter to boot! The only issues would be with intake/exhaust port size/flow and combustion chamber configuration. With all things being equal, unless the aluminum heads flowed more air at the same camshaft lift and at the same compression ratio, output power will be roughly the same.
Old May 11, 2006 | 01:03 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
That is good to hear. I was concerned with the compression being thrown off with the heads. As far as I know, the ports and things (unless I can find a ported set) are about the same. The 113s should flow much better than the swirl ports that are on it now (stock). I'll have to do some more research before I buy a set. Thanks for the help, guys.
Old May 11, 2006 | 01:46 PM
chesterfield's Avatar
Car: Pontiac
The 113s have the pre87 intake bolt pattern requiring modification of the tbi intake. the 113s don't have the exhaust crossover for EFE and EGR function. the ecm may have problems with that. Also they have raised d port on the exhaust which has been said to create issues with manifolds and/or headers.
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
