V-Belt vs Serpentine Question.
Old May 13, 2006 | 11:52 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
I have a 83 305 V belt, I just got a 91 350 serp... can I swap the v belt stuff on the 91? no problems?
Old May 13, 2006 | 01:38 PM
bretsk2500's Avatar
Car: 88 Chevy K2500
Engine: 350 TBI
Axle/Gears: 14b SF 3:73
all you'll need is a reverse rotation waterpump and fan (or use E fans), serps turn the WP backwards compared to a V belt setup.
Old May 13, 2006 | 04:26 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
So does the cooling itself flow differently? or can I use the water pump from my V-belt car...? Or does the block itself require a reverse flow pump with a v-belt pulley?
Old May 13, 2006 | 04:40 PM
camaronut79's Avatar
Car: 1983 z28
Engine: 383 .060=388
Transmission: th350
you got what he said mixed up.nelapse you want to put the vbelt stuff on your new motor right to anwser you question yes everything from the 305 will switch over with no problems.
Old May 13, 2006 | 05:16 PM
bretsk2500's Avatar
Car: 88 Chevy K2500
Engine: 350 TBI
sorry, I read it as he got a '91 serp setup and wanted to put it on the 305.
Old May 13, 2006 | 07:08 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
I appreciate it
ZZ3Astro
Aug 13, 2019 12:57 AM
jrdturbo
Mar 31, 2016 02:58 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
corey8084
Sep 17, 2015 02:56 PM
Ian Irvine
Sep 4, 2015 08:08 AM
