another lifter question.
Old May 13, 2006 | 03:13 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
My newly rebuilt 350 has started to tick until it is driven for 1-2 mins. Idleing doesn't make it stop. I took the cover off and it is the front valve on # 1. I tried tightening it and it stopped for a while but then it started again. It only does it on start up only. It has good oil psi. and the studs are fine . they are 416 heads.
if i replace just that lifter do i just run it like a cam break in?
My engine warranty pays me $35/ hour by the chiltons guide to fix anything since i did the install. I just wanted your opinions before i called them.
thanks.
Old May 13, 2006 | 05:58 PM
ede's Avatar
ede
think i'd put an indicator on a couple two or three lifters as well as the one in question and see what sort of reading(s) you get
ZZ3Astro
Aug 13, 2019 12:57 AM
skinny z
Oct 5, 2015 06:23 PM
corey8084
Sep 17, 2015 02:56 PM
dimented24x7
Sep 6, 2015 03:51 PM
Ian Irvine
Sep 4, 2015 08:08 AM
