Chain-driven vs. Gear-driven Timing Gears
Old May 14, 2006 | 11:00 PM
Jacobs454's Avatar
Car: '89 RS
Engine: LT1 350 9C1
I was thinkin about installing a gear-driven timing setup instead of the chain-driven type since I'm gonna be pullin the front of the motor off this weekend anyway. Is there any disadvantage to the gear-type? Thanks a MILLION!
Old May 14, 2006 | 11:04 PM
manchesterbeast's Avatar
Car: 1985 pontiac trans am
Engine: 350 with carb and headers
Transmission: borg warner 5speed
makes more noise
Old May 14, 2006 | 11:09 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Originally Posted by manchesterbeast
makes more noise
Which makes a good point, don't do it if you have a Knock sensor on a factory EFI engine.
Old May 14, 2006 | 11:43 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Well, it doesnt seem to affect my knock sensor on my motor...which is an '89 TPI 350. But it is loud. I like it now, but I can see it being annoying in a few months or early in the morning when Im hung over and just want to get to work. Though, timing gears are more accurate to slight degree and generally are used for race applications to maintain the accurate timing...which probably isnt necessary in your engine application. So unless you like the noise, I wouldn't do it.
Old May 15, 2006 | 01:52 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
try a search on gear drives . There is alot of stuff already here. Lots of arguments too .
Old May 15, 2006 | 02:16 PM
JesasaurusRex's Avatar
chp or car craft did a review on this a lil ways back. Between a timing chain, gear drive, belt drive, and some other fancy crap. I think there was like a 1hp difference between all of them. So choose what you wish. If you getta pete jackson, the quiet one I couldnt hear, and now the loud one I can't hear . No but thats what happens when you have no mufflers. On the outside of the car the quiet i couldnt really hear to well, the loud you can definetly hear a whine. Wish I stuck with the quiet but what ever.
Old May 15, 2006 | 02:27 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
also doesn't the gear drive weigh more?
Old May 15, 2006 | 02:44 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
You will get lots of mixed info about the gear drives...
Some will say it screws with knock sensors some will say it has no effect. Some say they are more acurate than a chain some say a good chain is no different. and so on...
Old May 16, 2006 | 11:06 AM
Guest
Guest
Posts: n/a
I'm not sure if there's any more rotating mass with a gear drive or not. I'd think not, the idler gears are fairly small and you dont have all that mass around the outside of the cam gear or crank gear like with a chain.
If you arent looking for the noise, I wouldnt do it. Some people find it downright annoying.
Old May 16, 2006 | 07:47 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I had a noisy set in my car. After 5 passes down the track, I put a chain back in. A noisy gear drive is very annoying.
Of course with the dual air filters sticking out of the hood, it sounded like I had a blower under the hood.
Old May 16, 2006 | 09:35 PM
Jacobs454's Avatar
Car: '89 RS
Engine: LT1 350 9C1
I think the noise sounds pretty sweet. Like Steven said, it sounds like a supercharger under the hood. Are they pretty easy to install and how long do they last compared to the chain? THANX!
Old May 16, 2006 | 09:42 PM
But theres no super charger under the hood so its rice...why i wish i got a quiet one
Ive had 2 now with no problems, pretty easy to install, might have to grind a little of the back lil spacer thing on the idler gear but no biggie
Old May 18, 2009 | 11:02 PM
lamarpro89's Avatar
Car: '82 Camaro
Engine: Slightly built 350
Transmission: 3A
Axle/Gears: unknown
Re: Chain-driven vs. Gear-driven Timing Gears
It is actually very annoying, I have a 350 with gear timing among other mods, and inside the car thats all you can hear. the very first drive with it was cool, now its downright loud and annoying
eightsixseven
Dec 16, 2024 01:50 PM
junkcltr
Aug 2, 2019 11:12 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
86White_T/A305
Aug 17, 2015 12:16 AM
