whos running an edelbrock 2 piece timing cover(4242)
Old May 16, 2006 | 04:04 PM
BOTTLEDZ28's Avatar
Transmission: A4
I have a 87+ rollor motor and I swear I am running the Edelbrock 2 pc timing chain cover on it even though Jegs and Summit both say it wont fit any 87 and later engines. I am trying to buy new gaskets for it and I dont know if I need special ones specific to this cover or if I can get away with buying 2 regular gaskets. I know for a fact that my cover is from Edelbrock and it IS a 2 piece design. I also know for a fact that my engine is a 87+. what gives here.
Old May 16, 2006 | 05:54 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The bolt patterns and gaskets are the same before and after 87. They're probably more concerned with it clearing the timing set.
Old May 16, 2006 | 05:56 PM
BOTTLEDZ28's Avatar
Transmission: A4
well, it my timing set doesnt rub on it so it must work then. thanks
Old Aug 3, 2008 | 12:57 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Re: whos running an edelbrock 2 piece timing cover(4242)
Yeah I used it too on my Roller block and no problems, the oil pan gasket is a little tighter of a fit but if you lube it up it will slid in no problem.
Old May 1, 2014 | 02:19 PM
downsouthboy's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 383 w/ vortec heads
Transmission: WC T-5 w/ SPEC lightweight clutch
I just installed one on my '76 model engine. But that set has 3 studs tack welded to the " adapter" plate at the bottom to help pull the front cover to the back piece. It does require a special gasket. But you could probqably make your own without too much effort
1992 Trans Am
May 10, 2023 07:19 PM
bryan623
Mar 22, 2021 06:43 PM
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Aug 17, 2015 02:00 PM
MY87LT
Aug 17, 2015 08:43 AM
