best cam for stock intake
Old May 17, 2006 | 01:14 PM
graphicideas1's Avatar
i am sending my stock heads out to be redone - what would the best cam i could use with a stock intake, flowtech headers & all the bolt on stuff. I know i will be needing to change my spring but should i also change my rockers to 1.6's?
Old May 17, 2006 | 02:12 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
cams are a science. cough up more info here, and you'll get better info.
head casting number
induction? (carb, fi?)
what year is the motor?
flat tappet or roller cam?
might as well get the right cam, then just get 1.5 roller tip rockers.
redone? be specific, what's being done? going to do any porting?
Old May 17, 2006 | 03:51 PM
I will be using my maf tpi setup on a 1988 350 and i want to stay with a roller cam - as for the heads i was going to get the "bowl cut" and a 3 angle valve job - the machine shop said that match porting my heads with a stock tpi set up is a waste of money because of how bad the castings are in the plenum, runners & intake???
Old May 17, 2006 | 06:27 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
If you plan on staying with tpi I would get a comp xr264hr or a comp xr269hr. Make sure the machine shop prepares the heads for screw in studs and machines the spring pockets for the valve springs comp recomends.
Old May 17, 2006 | 06:30 PM
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
hell might as well have it done now and change intake later.....I mean hell even if ya get a 2 or 3 hp boost out of it now to add more later with an intake change
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
camaro71633
Sep 1, 2015 10:24 AM
masonta
Aug 31, 2015 10:14 PM
